17 years agoIs a SRAM necessary in a cycloneiii?
Is a SRAM necessary in a cycloneiii system? Can I use a sdram as a program memory instead use a sram? Or can I use two individual sdrams in the same system?
17 years ago --- Quote Start --- To FvM:Which effective operation is of SRAM? --- Quote End --- Programm execution from SDRAM is involving larger latency, for this reason most NIOS applications are using SRAM for code, also Altera and Terasic Dev Kits. But it must not necessarily be the best choice for your application.
