17 years agoIs a SRAM necessary in a cycloneiii?
Is a SRAM necessary in a cycloneiii system? Can I use a sdram as a program memory instead use a sram? Or can I use two individual sdrams in the same system?
17 years ago --- Quote Start --- I guess, you are talking about a system with a NIOS II processor. It requires SRAM for effective operation. --- Quote End --- Thank you all. To FvM:Which effective operation is of SRAM? To DaiXiWen: My application is very big and the SRAM capability is too little. To MSchmitt :I want to use reset address to on-chip memory and program data in ddr.Does I can do that?
