15 years agoIOWR and IORD with PIOs
I have a basic question concerning PIOs. Currently, I am sending 4 8-bit integers over 4 ouput PIOs from NIOS to hardware to do a calculation on them and return another 8-bit integer value. This is a...
15 years ago --- Quote Start --- -When I have two IOWRs sequentially as in my code above, do these two 'writes' happen at the same time, i.e. does the hardware module who is waiting fot the data get them all at once ? --- Quote End --- In such cases the writes happen sequentially, but the time between them could be umpredictable. It depends from your hw and sw. For example you can have another Avalon master acquiring the control of the bus between them; or your program have to serve an irq. I don't think in any case the PIO would switch all at once; you need a latch module if you want to sinchronize them. --- Quote Start --- - To increase calculation speed, my next step will be to instantiate 2 calculation modules in my top level .v file, and modify the for-loops such that my image is divided into 2 (i.e. 4x5 and 4x5), and data from each sub-image goes to its respective hardware module instantiation. To do this I will need another set of PIOs (2x32bits out and 1x8bits in). Is this the right way to do it? If keep dividing my big image into more sub-images e.g 4, do I add another 2 sets of PIOs? I will end up having many sets of PIOs if my image is bigger and I want to sub-divide more! --- Quote End --- I don't understand clearly what you mean and if it is really correct for your purpose. Probably yes. And normally dividing the main task and replicating hardware in such way brings to a great improvement in speed, but also to a great increase of fpga resource utilization; you must seek the optimal configuration for your actual system. --- Quote Start --- Is there a better way to transfer the data from NIOS to the different hardware modules? Another forum member has suggested to create a wrapper module for all my instantiations and create an Avalon MM to interface to the array, but I am completely lost! Can somebody please guide me a bit through this? --- Quote End --- What the other member suggested is generally exact. PIOs are very inefficient if you want to write an external register and aMM slave interface is more convenient. But in your case I see you don't have a 'real' memory interface, being your external module totally asynchronous (and maybe combinatorial?): so I don't see any improvement in switching from PIO to Avalon MM. However giving you informatio about Avalon MM here is not feasible, since it would require a lot of space. You'll learn more by browsing Nios/sopc documentation or searching in the forum. Regards Cris
