epissadakis
3 years agoIO_SERDES_DPA error in place and route step
I am trying to implement an RTL design which contains two LVDS SERDES receivers in SOFT-CDR mode . The received data will be redirected to LVDS SERDES transmitters and forwarded to ouput ...
- 3 years ago
I think that is the problem.
I had the same error when using pins from the same bank in two RX SERDES IP. Error got solved after changing the pins location of the inputs of one of the receivers, so using only one receiver IP for each bank works in my case.
AqidAyman_Altera
3 years agoAs we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
