IO_SERDES_DPA error in place and route step
- 3 years ago
I think that is the problem.
I had the same error when using pins from the same bank in two RX SERDES IP. Error got solved after changing the pins location of the inputs of one of the receivers, so using only one receiver IP for each bank works in my case.
Hi Manolis,
You must place RX interfaces in one I/O bank and each bank has only 12 PCLK resources, there are only 12 soft-CDR channels available.
To find out which pin pairs can support soft-CDR channels in each bank, refer to the device pin out file. In the device pinout file, the "Dedicated Tx/Rx Channel" column lists the available LVDS pin pairs in a LVDS<bank number>_<pin pair><p or n> format. If the value of <pin pair> is an even number, the pin pair supports soft-CDR mode.
Do you aware on this information?
