epissadakis
3 years agoIO_SERDES_DPA error in place and route step
I am trying to implement an RTL design which contains two LVDS SERDES receivers in SOFT-CDR mode . The received data will be redirected to LVDS SERDES transmitters and forwarded to ouput ...
- 3 years ago
I think that is the problem.
I had the same error when using pins from the same bank in two RX SERDES IP. Error got solved after changing the pins location of the inputs of one of the receivers, so using only one receiver IP for each bank works in my case.
epissadakis
3 years agoHi ,
Arria 10
Manolis
