IO_SERDES_DPA error in place and route step
- 3 years ago
I think that is the problem.
I had the same error when using pins from the same bank in two RX SERDES IP. Error got solved after changing the pins location of the inputs of one of the receivers, so using only one receiver IP for each bank works in my case.
Thank you for reaching out Intel FPGA Community.
Can you provide below information first? This is for better understanding.
- What is version of Quartus used for this project?
- Can you share the project file for us to replicate from our side?
Aqid
Unfortunately, i cannot share the project file. I use Quartus Prime Pro 22.1. As i understand there is only one IO_SERDES_DPA location per bank so when i try to instantiate more than one RX SERDES IP with different parameters it cannot be placed. Is this the problem ?
Manolis
- mbc3 years ago
