16 years agoIO current strength issue
1、Is the defalt current strength the max? How to change the defalt current strength for all io? 2、I found that the defalt (max) current strength are differ in differ io bank for...
16 years agoMay be a global current strength setting in device assignments existed with previous Quartus versions. But as far as I know, it doesn't, now. You can set rather easily a current strength for all pins in the Pin Planner, I think, but you can also apply a single line assignment for all pins in the Assignment Editor or enter it as a tcl command.
P.S.: I see, that a global "*" assignment doesn't work as with previous Quartus versions. So setting current strength in the Pin Planner to all pins or groups of pins seems to be the best way now.
