10 years agoInvalid JTAG configuration
I am using MAX10 10M50SAE-144C8GES installed on our board, with Quartus Prime 15.1, programming with USB Blaster rev C. I was debugging using SignalTap II, modifying the project, compiling and ...
10 years ago --- Quote Start --- Based on your description it sounds like power supply issue. Module that you're referring to might be disrupting the power to MAX10 rendering JTAG failure. --- Quote End --- jackyb0i, thank you for you thought. The power supply was OK. It is actually CONF_DONE pin strapping to Gnd.
