10 years agoInvalid JTAG configuration
I am using MAX10 10M50SAE-144C8GES installed on our board, with Quartus Prime 15.1, programming with USB Blaster rev C. I was debugging using SignalTap II, modifying the project, compiling and ...
10 years agoBased on your description it sounds like power supply issue. Module that you're referring to might be disrupting the power to MAX10 rendering JTAG failure.
