14 years agoIntra-clock period timestamp capture
Good afternoon,
I have an input pin which goes from low to high asynchronously. I am interested in WHEN this transition occurred. As the first step, I have a clocked counter and I record the value of this counter when the clocked process sees the pin transition low to high. However, I need to detect the transition time more accurately than the clock period. I know what I want to do in hardware, but worry that quartus will 'optimize' my circuit into something that's wrong. I want to ensure this doesn't happen... ideally as cross-vendor as possible. Here's my plan for detecting the intra-period offset: signal inp : std_logic; -- the input pin signal a, b, c, d : std_logic; -- the pin with increasing delay signal clk : std_logic; -- the main clock signal ra, rb, rc, rd : std_logic; -- captured trace a <= '1' and inp; b <= '1' and a; c <= '1' and b; d <= '1' and c; ... process(clk) begin if (rising_edge(clk)) then ra <= a; rb <= b; rc <= c; rd <= d; ... end if; end process; The idea here is that the input pin goes through some combinatorial logic that delays it. Then on the clock edge, I latch the logic in parallel registers. Afterwards, I can count how many registers stored a '1' to see how far the signal transition propagated. The further it went, the earlier it arrived. Calibration and conversion of these registers to an actual timestamp is a solved problem and not part of my question. My concern is that quartus will see that: a <= '1' and inp; is the same as: a <= inp; ... and eliminate my introduced delay. How can I force quartus to add delays to my signal between the capture registers. Is there a way to do this portably? (I will need to do it on a spartan6 afterwards as well).1 Reply
Might lcell be what I'm looking for?
... I somehow didn't find this on my previous google searches.
