15 years agoInterrupt Problem
Currently i am working on low level driver for Nand Flash in NIOS II.In my system following component are included DDR_SDRAM,JTAG_UART,PERFORMANCE COUNTER,PIO(LED),NFC(Nand flash controller).In my sy...
15 years ago@philipp
Hi , As per your suggetion like use Component IRQ id instead of component base address i made change according it but no effect of it. So it is same whether you use IRQ id or base address of the component. Now i also resolve my below problem /************************************************************************/ But now my problem is when i issue write or read API back to Back or say in for loop(say 10 times) it just suspended in RUN mode in NIOS II.but it's work very well in Debug mode. so what i make change in above code to solve above problem................. /*************************************************************************/ but putting some delay say 1 sec in write/read API.but it's not proper solution because it reduce the read/write performance.so pls give me other solution........................ Regards, Jayesh
