15 years agoInterrupt Problem
Currently i am working on low level driver for Nand Flash in NIOS II.In my system following component are included DDR_SDRAM,JTAG_UART,PERFORMANCE COUNTER,PIO(LED),NFC(Nand flash controller).In my sy...
15 years agoHi,
great you solved your problem! But still I am sure you are using alt_irq_enable and alt_irq_disable the wrong way. Don't use it with the BASE-address of your component. Instead, take the IRQ-id listed in system.h. CU, Philipp
