15 years agoInterrupt Problem
Currently i am working on low level driver for Nand Flash in NIOS II.In my system following component are included DDR_SDRAM,JTAG_UART,PERFORMANCE COUNTER,PIO(LED),NFC(Nand flash controller).In my sy...
15 years agoHi jayesh, donq!
Sorry I was on a trip yesterday. @jayesh: --- Quote Start --- so its right,problem occurs because of other thing not this. --- Quote End --- This might be true, I can't know it for sure. But alt_irq_enable(nfc_base); is not the right call to alt_irq_enable(). Take a look the HAL API Reference. --- Quote Start --- int alt_irq_enable (alt_u32 id) --- Quote End --- And with id it is meant to use <YOUR_MODULE_NAME>_IRQ. This is the id which also specifies the priority of your interrupt, at least with the LEGACY Interrupt API. I am pretty sure with this, because I've used the interrupt API quite a time. @donq: --- Quote Start --- Lots of altera macros are written based on the _BASE address of the device. --- Quote End --- That's true. But in general all MACROS are defined with big letters. And alt_irq_enable() isn't. It is a function call. --- Quote Start --- but I'd assume that alt_irq_enable() is such a macro --- Quote End --- No, it isn't. Maybe it is a INLINE function, I've to check on monday at work. But it is not a MACRO. Have a nice weekend! Philipp
