15 years agoInterrupt Problem
Currently i am working on low level driver for Nand Flash in NIOS II.In my system following component are included DDR_SDRAM,JTAG_UART,PERFORMANCE COUNTER,PIO(LED),NFC(Nand flash controller).In my sy...
15 years ago@pillemann
No,first i use NFC_IRQ in alt_irq_register(NFC_IRQ,edge_capture_ptr,handle_nfc_interrupts) to Register the interrupt request of Nand flash controller(NFC) then after i wrote code to enable IRQ of Nand flash controller(NFC) is below alt_irq_enable(NFC_BASE); so its right,problem occurs because of other thing not this. Thanks for your rpy Regards, jayesh
