17 years ago
Interrupt handling
I tried some example programs in Nios 2 using interrupt handling,
i made all the configurations required to generate the interrupt,including whether it is a level or edge and all those stuffs.I used an GPIO to generate an interrupt but whenever i change the state of the input the interrupt is not getting generated i have attached by code below
# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "nios2.h"# define BUTTON_PIO_IRQ 0# define BUTTON_PIO_BASE 0x00000000
volatile int edge_capture;
static void handle_button_interrupts(void* context, alt_u32 id);
void main()
void* edge_capture_ptr = (void*) &edge_capture;
NIOS2_WRITE_IENABLE(0xf);
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
alt_irq_register( BUTTON_PIO_IRQ,edge_capture_ptr,handle_button_interrupts);
while(1)
volatile int* edge_capture_ptr = (volatile int*) context;
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0);
Thanks in advance
Gowtham
1 Reply
