16 years agoInternally generated clock (VHDL)
If I generate a clock within a MAXII pld, I can output that signal to a pin, wire the pin to a spare global clock input and use it without problem. How do I do this connection internally witho...
16 years agoI don't understand your post. The Quartus fitter selects MAX II global clock signals automatically for respective signals, e.g. if you create a ripple clock, you can check in the fitter report resource section.
