14 years ago
Internal Error: Sub-system: ASMIO
Good day everybody,
i have this problem when the i try to generate the programming files (Assembler phase). exactly in 51% of the process
Internal Error: Sub-system: ASMIO, File: /quartus/comp/asmio/asmio_dqs.cpp, Line: 2257 re_oterm->has_fanout_exactly(1)
Stack Trace:
0x409a4: ASMIO_MIO_DQS_LOCAL_DQS_BUS_SELECT::process_atom + 0x474 (comp_asmio)
0x175ed8: process_cdb + 0x658 (comp_asm)
0x176b3c: assemble_chip + 0x33c (comp_asm)
0x17925e: assemble_dev_device + 0x12de (comp_asm)
0x17b840: asm_assemble + 0x380 (comp_asm)
0x3ddb: QASM_FRAMEWORK::execute + 0x6b (quartus_asm)
0xf211: QEXE_ARGS::get_command_line + 0x1461 (comp_qexe)
0x116b7: qexe_process_cmdline_arguments + 0x387 (comp_qexe)
0x117a4: qexe_standard_main + 0x84 (comp_qexe)
0x3ab0: qasm_main + 0x50 (quartus_asm)
0x1b81: msg_main_thread + 0x11 (CCL_MSG)
0x1be8: _thr_final_wrapper + 0x8 (ccl_thr)
0x1af5: msg_thread_wrapper + 0x85 (CCL_MSG)
0x458a: mem_thread_wrapper + 0x4a (ccl_mem)
0x28a03: msg_exe_main + 0x63 (CCL_MSG)
0x3d0c: _main + 0x1c (quartus_asm)
0x4523: __CxxThrowException@8 + 0x15f (quartus_asm)
0x13676: BaseThreadInitThunk + 0x11 (kernel32)
0x39f01: RtlInitializeExceptionChain + 0x62 (ntdll)
0x39ed4: RtlInitializeExceptionChain + 0x35 (ntdll)
End-trace
Quartus II Version 11.0 Build 208 07/03/2011 SJ Full Version
Service Pack Installed: 1
hope you can help thanks!!!
    I faced the same issue and managed to resolve it.
    Deleting db and incremental_db from the project file sorted this out for me..If this does not work..You will need to install another version of Quartus.. Atleast Quartus 9.1 sp2..
    Rgds,
    BVP
    its difficult to diagnose without Altera's help, you should file a service request
