16 years agoInterfacing the FPGA to a micrcontroller
I am designing a circuit that is to carry out a correlation funciton on two sets of input waveforms. The value after the calculation is stored in D flip flops. It is update continuosly as the calcula...
16 years agoHi,
You can set the output port to high impedance when the chip select from the MCU is high/low(depends on the active level). For example:
reg reg_calc_data;
wire databus;
assign databus= (chipselect) ? reg_calc_data : 8'bZZZZZZZZ;
For the data availability you can use a dual port fifo ram. Here is some example http://www.asic-world.com/examples/verilog/asyn_fifo.html Quartus has a build in Megafunction for FIFO memory. Take a look at the megafunctions documentation. Best regards, VT
