13 years agoInterfacing FPGA with real hardware
Hello I'm newbee with FPGA and CPLD and start using them since the beginning of the year. I've finished an hardware for my old 8bit computer and all work well (interface CF) I've put ...
13 years agoIIRC the megafunction ROM has a rden (read enable) input.
Then, you must provide simple glue logic to interface /OE /CE signals coming from external processor. A single AND with negated inputs (namely active high OE, CE) could be enough: rden = OE AND CE You also need to tristate the FPGA-ROM data output when /OE il high, to avoid bus contention. The megafunction ROM also requires a clock. Use any clock available in fpga. Take care it has a period shorted than the processor read cycle; if you can't accomplish this, your processor should add wait states for ROM reads.
