9 years agoInterfacing DDR or SRAM
Hello, Iam so sorry for my newbie question but i've already read sooo many literature but iam not sure what is what. Sooo. I need high count of BLVDS. Iam using it on my backbone as data c...
9 years ago --- Quote Start --- Because cyclone V does not support BLVDS --- Quote End --- Not completely right. AN522 suggests to use Differential SSTL-2 to implement BLVDS with Cyclone V. --- Quote Start --- if DDR's are 4n prefetch then bandwidth is 200 MHz x 32b x 4 = 25 600 Mbit/s. --- Quote End --- Can't follow your calculation. DDR is double data rate, not quad data rate. In addition, you can stream out a full row continuously, but some housekeeping and setup of next transfer has to be performed. Expect e.g. 95% of burst transfer rate for large blocks. Performing concurrent read and write will further halve the bandwidth.
