10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years ago --- Quote Start --- You use different address values to access your module. For example: address 0 => input 0, address 1 => input 1, address 2 => output. Your code needs to look at the address lines to decide what is being accessed. Read the material I mentioned on Qsys. It's explained there. --- Quote End --- For PIO connected to Lightweight AXI, for example, if you want to read or write an address with the same offset ,the adress you need to pass to the function is the same, the only change is the function (read or write)
