10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years ago --- Quote Start --- Good evening Galfonz, i am new in Qsys and Quartus, so can you please help me and give me an example as demonstration on how to use your suggestion of address ( plz if you can send me a code similar to this). Thank you so much --- Quote End --- Hi Sarahmed, we still don't know how is made your adder, have you register? Please can you post code so we see both adder logic and interface you plan to use? For what are you planning to use this adder? Is processor on QSYS too? To learn try this step by step tutorial http://www.badprog.com/electronics-quartus-ii-creating-your-first-sopc-with-qsys-and-nios-ii-software and some hint from here http://www.alteraforum.com/forum/showthread.php?t=40210 TO have example you need give us at almost an approximate idea of what you think build around adder, then we can guide you. Regards
