10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years ago --- Quote Start --- Thank you so much Galfonz iam new learner, and iam trying to interface an adder with avalon bus in Qsys. i wrote a VHDL code for the adder, and i added another vhdl module to create an interface_avalon (i added the following interfaces: CLK, reset, write, writedata, readdata, chip select and external port). But, the adder has 2 inputs and 2 out put, how can i add two datawrite and dataread(it is allowed to add just one) to connect them to the 2 inputs and outputs of the adder thanks again --- Quote End --- A simple adder has no sense on AValon other than using conduit for a special interface. Adder is registered and require clock or is just a basic combinational adder? Please can you post your code to see how it is interfaced from top level?
