10 years agointerface a module with avalon bus
Good evening; i want to know how to interface a module HDL with the avalon bus if any one can answer me Thank you
10 years agoThank you so much Galfonz
iam new learner, and iam trying to interface an adder with avalon bus in Qsys. i wrote a VHDL code for the adder, and i added another vhdl module to create an interface_avalon (i added the following interfaces: CLK, reset, write, writedata, readdata, chip select and external port). But, the adder has 2 inputs and 2 out put, how can i add two datawrite and dataread(it is allowed to add just one) to connect them to the 2 inputs and outputs of the adder thanks again
