17 years agoInteresting DDR2 Memory Problem
Hi, I am using the DDR2 SDRAM HP controller for a 1GB DIMM (though i am only attempting to use about 128MB). Initially, I thought I was having timing problems since I always got memory fai...
17 years agoIf I understand right, only some of many test reads are failing. If so, a problem of signal quality or timing should be expected.
