Muralidharan
3 years agoIntel Max 10 FPGA VCC and GND short after few days
Hi, Greetings! History: We are using Intel 10M25SAE144I7G FPGA in the design. Rev1 Board is working fine, in the Rev 2 Board we used the same FPGA design code and some of the pins assigned as input/ ...
Zawani_M_Intel
2 years agoHi Muralidharan,
Hope that my answer can help you.
We recommend to connect non-driven output pin to be connected to GND. You can set the pin to GND by using Quartus. Physical connection is not needed as the connection is already exist in FPGA package.
Thank you!
Wani
