Muralidharan
3 years agoIntel Max 10 FPGA VCC and GND short after few days
Hi, Greetings! History: We are using Intel 10M25SAE144I7G FPGA in the design. Rev1 Board is working fine, in the Rev 2 Board we used the same FPGA design code and some of the pins assigned as input/ ...
Farabi_Altera
3 years agoHello,
- Are you able to do the IV curve?
- how many units observed the same?
- can you snapshot the top marking of the fail unit?
- Do you want to send the unit for FA?
regards,
Farabi
- Muralidharan3 years ago
Hi Farabi,
Thanks for your response!
1. I biased at 1.8V and gradually increased the current till 1A during my debug and observed FPGA heats more than 80 degress, disconnected the power immediately and I haven't done further testing.
2. 4 units at different intervals. Initially it works after continuous usage, it experiences sudden heat and fails!
3. Sure, I'll share by Monday.
4. Currently it is on the board, I need to desolder. I'll update you later on the shipment for FA. Yes, I can send if needed.
5. Any suggestion, what are the possible causes for FPGA failure? I have put design release on hold because of this failure!
