8 years agoIntel HLS (High Level Synthesis) compiler
Hello all, I am using Intel HLS compiler Quartus Prime Lite edition and going through solved examples to learn more about the tool. Has anyone implemented a particular example in Intel HLS wh...
8 years agoHi,
"Does lite support the HLS compiler?" To install the Intel HLS Compiler, install Intel Quartus Prime Standard Edition software or the Intel Quartus Prime Pro Edition software. For example you can refer or check the installation directory https://alteraforum.com/forum/showthread.php?t=57668 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
