Gizmotoy
8 years agoIntel AN829 PCIe DMA example failing to create /proc/devices entry
I'm working on bringing up AN829, the Altera DMA example, on a Cyclone 10 GX Development Kit. The FPGA is loaded and shows up on the PCIe bus. 05:00.0 Non-VGA unclassified device: Altera Corporatio...
Gizmotoy
7 years agoI was able to get it working, but it was by switching to a machine with a larger PCIe address space. I kept getting <unassigned> for the memory space when I was on the other computer. It's not a great solution, but it worked.
WCarb1
7 years agoYes, in machines with larger PCI address memory space I had no problems. In fact, the issue was in one particular embedded device with limited memory space. However, I managed to solve it modifying the IP core from system designer to have a smaller PCIe memory size and changing the base addresses. Also the driver kernel from the linux side required some tuning for these new memory chunks. Thank you for all your help!
