Gizmotoy
8 years agoIntel AN829 PCIe DMA example failing to create /proc/devices entry
I'm working on bringing up AN829, the Altera DMA example, on a Cyclone 10 GX Development Kit. The FPGA is loaded and shows up on the PCIe bus. 05:00.0 Non-VGA unclassified device: Altera Corporatio...
SengKok_L_Intel
7 years agoJust FYI.. I recently tested AN829 in centos for Arria 10 device, everything is working fine. Perhaps, you can check if the same problem happen in other Linux OS and see if there is any dependency.
