Gizmotoy
8 years agoIntel AN829 PCIe DMA example failing to create /proc/devices entry
I'm working on bringing up AN829, the Altera DMA example, on a Cyclone 10 GX Development Kit. The FPGA is loaded and shows up on the PCIe bus. 05:00.0 Non-VGA unclassified device: Altera Corporatio...
SengKok_L_Intel
8 years agoJust try to understand the problem in more detail:
- Did you follow the AN 829 1.2.7 installing the DMA test driver (e.g. sudo ./install cyclone10) ?
- Did you success to run the DMA application in step 3 (./run)?
Here is the link of the AN 829:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an829.pdf
Regards -SK
