Michael2021
1 year agoIntel® Arria® 10 FPGA – Intel DisplayPort 8K RX-Only Design Example
Hello, I'm trying to look at this design. I downloaded the A10_DP_RX_FMC_PRO.par file and compiled it with Quartus Pro 21.1. I'm trying to compile the CPU program file in the Additional_Files dire...
Michael2021
1 year agoHi Ven,
Thank you for your reply.
After opening the altera Nios2 Command Shell, I proceeded as in document an900.
However, I have confirmed that the dp_demo.elf file has not been updated successfully.
The error message is as follows:
"nios2-bsp-update-settings : command not found"
thank you
Michael
Michael2021
1 year agoHi anybody,
I install additional distro packages as below
sudo apt update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt install build-essential
I don't know why "nios2-bsp-update-settings" command is not found.
I think this is a very basic question. If anyone knows, please let me know.
Michael
