11 years agoinserting delay buffer at output pin of FPGA
hi all, I want to add a small delay to one of my outputs, just to test/try out an idea. I need about 10-15ns, while my clock is 204ns period. Looking around the web, I see some people using ...
11 years agoUsing an additional tap from the PLL sounds like a reasonable option, and also will be compensated across voltage and temperature. If you go and insert logic in the path, you will get very different delays between slow and fast corner since the effect of process voltage and temperature in CMOS circuits varies greatly.
