Inquiry About Compatibility of Multi Channel DMA IP Driver with Agilex 7 M-Series Board
Hi admaris,
Thanks for reaching out.
Yes, according to the design example user guide, the Agilex 7 M-Series Dev Kit is not supported for the Design Example hardware test for MCDMA R-Tile and F-Tile. However, this does not mean that the device OPN (AGMF039R47A1E2VR0) cannot support the MCDMA IP design example.
When creating a new project in Quartus, choose the Agilex 7 M-Series Dev Kit. Select the R-Tile/F-Tile MCDMA IP from the IP Catalog. In the IP Parameter, choose 'NONE' in the 'Target Development Kit' when generating the design example. You need to perform the pin assignments manually. You will also need to write your own software/driver for the hardware testing. You may refer to the existing driver and software application provided in the generated Design Example for the supported Dev Kit in MCDMA R-Tile/F-Tile.
Currently, there is no reference design available with a driver that supports the Agilex 7 M-Series Dev Kit.
Multi Channel DMA Intel® FPGA IP for PCI Express* Design Example User Guide: https://www.intel.com/content/www/us/en/docs/programmable/683517/24-3/introduction.html
Ven
