12 years agoInput problem for PLL block
Hi Everyone, I am thinking using PLL for clock derivation,but I have a problem for PLL inputs.There are 11 inputs for PLL and I wanna use multiplexer (created in FPGA) before PLL to select one ...
12 years ago --- Quote Start --- Hi Everyone, I am thinking using PLL for clock derivation,but I have a problem for PLL inputs.There are 11 inputs for PLL and I wanna use multiplexer (created in FPGA) before PLL to select one of them as a input for PLL.but As I see PLL don't accept multiplexer output as input. I think I have to route Muxtiplexer output to FPGA output and then , I have to take it as a input from another FPGA pin.So,I can use this signal for PLL input. but I don't want to waste FPGA pins. Do you any idea How can I use multiplexer outputs for PLL inputs ? If you share your ideas ,I really appreciate this. Thanks in advance --- Quote End --- The PLL ref input must be clean signal relative to PLL requirements. You can use one ref clock into a PLL with multiple outputs then insert a clock mux afterwards on various PLL outputs
