15 years agoInput decay and state machine deadlock
Hello, I have an Altera device that gets an input from another board. This input drives a complex state machine. When I remove the power from the other board, the input goes low in a 5ms non-...
15 years agoMissing synchronization of asynchronous inputs must generally be expected to cause a state machine to get stuck in illegal states. As already mentioned, the synthesized logic ignores any unused respectively illegal states and thus don't necessarily recover from them.
Besides correct synchronization, which is recommended anyway, "safe" state machine encoding will reliably prevent locking in illegal states. It can be specified per FSM defintion by synthesis attributes:// Safe State machine in Verilog
reg my_fsm /* synthesis syn_encoding = "safe" */; -- VHDL
TYPE STATE_TYPE IS (s_idle, s_sync1, s_sync2, s_sync3, s_data, s_check);
ATTRIBUTE syn_encoding : STRING;
ATTRIBUTE syn_encoding OF STATE_TYPE : TYPE IS "safe";
SIGNAL state : STATE_TYPE;
