16 years agoinout ports for multiple modules
I'm working on a design based on an existing system designed in AHDL. Currently the design has quite a few modules in AHDL connected with a block diagram at the top level. The product has an e...
16 years ago --- Quote Start --- INOUT or BIDIR pins can not be connected together in anything other than a block diagram file, correct? --- Quote End --- They can be connected in HDL as well. But you should consider, that multiplexers are inferred for the output data direction and that a mutual exclusive selection condition for the individual module's output enables must exist. But that's the same in schematic entry, I think.
