14 years ago
inout line undefined
Here is the code that is confusing me. This is not the whole program, just a component.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Serial_Communication is
Port ( i_CLK, i_CLKx2, i_EN, i_RD : in STD_LOGIC;
i_ADDR : in STD_LOGIC_VECTOR(6 downto 0);
io_DATA : in STD_LOGIC_VECTOR(15 downto 0);
io_SD : inout STD_LOGIC;
o_SEN, o_SCLK, o_DONE : out STD_LOGIC);
end Serial_Communication;
architecture Behavioral of Serial_Communication is
component CLK_Interrupt is
Port ( i_CLK, i_interrupt, i_idle_state : in STD_LOGIC;
o_CLK : out STD_LOGIC);
end component;
signal clk : std_logic := '0';
signal clkx2 : std_logic := '0';
signal sclk_interrupt : std_logic := '1';
signal clk_e : std_logic := '0'; -- early clk
signal clkx2_e : std_logic := '0'; -- early clkx2
signal clkx2_d : std_logic := '0'; -- delayed clkx2
signal sen : std_logic := '0';
signal o_sd : std_logic := '0';
signal i_sd : std_logic := '0';
signal tristate : std_logic := '0';
signal done : std_logic := '0';
begin
clk_e<=i_CLK;
clkx2_e<=i_CLKx2;
clk<=clk_e after 15ns;
clkx2<=clkx2_e after 15ns;
o_SEN<=sen;
o_DONE<=done;
V1: CLK_Interrupt port map (
i_CLK => clk,
i_interrupt => sclk_interrupt,
i_idle_state => '0',
o_CLK => o_SCLK);
process(clkx2, i_EN)
variable count : integer := 0; -- clkx2 counter
variable run : boolean := false;
begin
if clkx2'event and clkx2='1' then
if i_EN='1' then
run:=true;
end if;
if run=true then
count:=count+1;
else
done<='1';
count:=0;
end if;
if count=1 then
done<='0';
o_sd<='0';
tristate<='0';
elsif count=2 then
o_sd<=i_RD;
sen<='1';
elsif count=3 then
sclk_interrupt<='0';
elsif count<18 then
o_sd<=i_ADDR((17-count-(17-count)mod 2) /2);
elsif count<50 then
if i_RD='0' then
o_sd<=io_DATA((49-count-(49-count)mod 2) /2);
else
end if;
elsif count=50 then
if i_RD='0' then
o_sd<='0';
else
end if;
elsif count=51 then
sclk_interrupt<='1';
sen<='0';
elsif count=52 then
done<='1';
run:=false;
count:=0;
end if;
end if;
end process;
clkx2_d<=clkx2 after 15ns; -- makes sure the o_sd value is set before it is given out to io_SD
process(clkx2_d, tristate)
begin
if clkx2_d'event and clkx2_d='1' and tristate='0' then
io_SD<=o_sd;
end if;
end process;
end Behavioral;
When I simulate my entire program the io_SD inout line is undefined whenever the i_EN line is '0'. If i_EN='1' then all signals are what they should be. Once the component, that is driving this one, sets i_EN to '0' simulation just ends. Changing the simulation run time does not work, it simply ends after i_EN='0'. If I start off with i_EN='0' then simulation run time is again a constant (15ns) and the io_SD is labeled "U", meaning undefined.
I assumed that the simulator was buggy and tried programming the FPGA. The program did not work as expected.
Maybe I should also mention that I am using xilinx ise project navigator 10.1.03(nt) for coding in vhdl. The FPGA is Xilinx Spartan XC3S1200E.
    The problem is when count=0 the wrong elsif statement is entered. I have fixed it already.
    Thank you for your help.
    I can see the process (referred to in the error) working properly in the simulation. All is well until in_EN goes low. Meaning the proper waveform is shown on the proper lines. When in_EN goes low the simulation just does not go further, I can increase simulation run time but simulation it self does not go any further.
    If I start the program with in_EN low, the simulation runs for 15ns only and the io_SD line is shown undefined. And same thing occurs, I can increase or decrease simulation time but it does nothing when I increase it past 15ns.
    --- Quote Start ---
    I should have mentioned this earlier. There is an error when I simulate the program: "ERROR: Simulation:595 - Index 8 out of bound 6 downto 0." "ERROR: In process Serial_Communication.vhd:71"
    --- Quote End ---
    It means your algorithm for address calculation is wrong as it calculates index 8.
    Well this is what a good testbench and simulation are all about - debugging.
    The future plan is to use this component for reading and writing. Right now I am trying to get the writing to work only. That is why the inout is used only as out for now. The i_EN signal comes from a different component. I don't want the counter to count when i_EN is low. i_EN meaning "Enable input signal". The problem is that somehow the io_SD is undefined when i_EN is low.
    I know I should be using Xilinx's forums, sorry about that.
    I tried posting on Xilinx forum but I could not find out how.
    For a start - this is an Altera forum - for Xilinx specific problems you should really go to the Xilinx forum.
    But asside from that - I dont know what things should be? having a quick look over this code, the counter wont start counting until i_en = '1', and you have nothing defined for when count = 0.
    And why is io_SD an inout? you never read it, so it should just be an Out.
