14 years agoinfo about a report :(
Hi all I am trying to study a report for the setup times of signals. I am not able to understand what the rise and fall indicates with respect to clock and the signal. IF anybody can guide...
14 years agoI believe it's when the data is rising and when it is falling coming into the device. I would recommend using set_input_delay to constrain the ports rather than using the datasheet report, as running report_timing on a constrained path will give a lot more detail.
