12 years agoInfering DSP block in Arria V
Hello I'm trying to infer DSP blocks in my Arria V design as a replacement for my former ALTMULT_ADD instance in Stratix III. I notice that the input registers are placed outside (i.e. the DSP ...
12 years agoAccording post-fitter netlist, the Altera template unsigned_multiply_accumulate will be completely implemented in DSP block.
-- Quartus II VHDL Template
-- Unsigned Multiply-Accumulate
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity unsigned_multiply_accumulate is
generic
DATA_WIDTH : natural := 8
port
a : in unsigned ((DATA_WIDTH-1) downto 0);
b : in unsigned ((DATA_WIDTH-1) downto 0);
clk : in std_logic;
sload : in std_logic;
accum_out : out unsigned ((2*DATA_WIDTH-1) downto 0)
end entity;
architecture rtl of unsigned_multiply_accumulate is
-- Declare registers for intermediate values
signal a_reg : unsigned ((DATA_WIDTH-1) downto 0);
signal b_reg : unsigned ((DATA_WIDTH-1) downto 0);
signal sload_reg : std_logic;
signal mult_reg : unsigned ((2*DATA_WIDTH-1) downto 0);
signal adder_out : unsigned ((2*DATA_WIDTH-1) downto 0);
signal old_result : unsigned ((2*DATA_WIDTH-1) downto 0);
begin
mult_reg <= a_reg * b_reg;
process (adder_out, sload_reg)
begin
if (sload_reg = '1') then
-- Clear the accumulated data
old_result <= (others => '0');
else
old_result <= adder_out;
end if;
end process;
process (clk)
begin
if (rising_edge(clk)) then
a_reg <= a;
b_reg <= b;
sload_reg <= sload;
-- Store accumulation result in a register
adder_out <= old_result + mult_reg;
end if;
end process;
-- Output accumulation result
accum_out <= adder_out;
end rtl;
