13 years agoIndefinite states of State Machine - VHDL
Hi Guys, I would like to ask for your help... I wrote a simple code that is identifying the rising edge of incoming signal. There are two states - every time that rising edge existing, the st...
13 years ago --- Quote Start --- I suppose your incoming signal is asynchronous to your processing clock. As such it will have a different propagation delay to each register in the state machine and in the end each of the state-machine registers may see a different level, and possibly clock in an invalid transition ending up in an undefined state. So you have to synchronise this external input with a two-stage register chain to avoid this (and metastability) issue. --- Quote End --- Thanks for your answer. The external incoming signal is really asynchronious with the Primary Clock...As I understand, I have to transfer the icoming signal through FF that's syncronised with Primary Clock? I would like to add more details... The x"00" state disappear when I determine one or more states that I am not using - spare states. Instead of x"00", I see the last state but still missing the rising edge.
