18 years agoIncremental compilation and NIOS - Bottom Up
Hi all, I'm using incremental compilation in a mix mode (all is top down) but I would like to have the nios in Bottom Up so that the people that develop it can change its part and give me the .qxp fi...
18 years agoOk thanks both, I've missed that paragrah on qII handbook.
The solution is simply to copy the CPU_Supervisor.vhd that was created by SOPC with the NIOS (Yes my partition include all the SOPC block). For the relative assignment you can do that in the Quartus II, but on SOPC you cannot (or at least I can only add path and not edit one (I'm speaking of the menu under Tools/Option/IP Search path of the SOPC Builder). If can be helpfull I'm using QII ver 8.0 sp1 (the last available). Thx both for the help/support
