18 years agoIncremental compilation and NIOS - Bottom Up
Hi all, I'm using incremental compilation in a mix mode (all is top down) but I would like to have the nios in Bottom Up so that the people that develop it can change its part and give me the .qxp fi...
18 years agoYou can do relative paths. When you add them into menu, just edit the absolute path to make it relative. (I think if you add anything under the project directory, it is added relatively, and anything outside is an absolute path, but you can modify either one.) If that's all your trying to solve, I would recommend against the .qxp flow.
