18 years agoIncremental compilation and NIOS - Bottom Up
Hi all, I'm using incremental compilation in a mix mode (all is top down) but I would like to have the nios in Bottom Up so that the people that develop it can change its part and give me the .qxp fi...
18 years agoThe quartus flow currently does:
quartus_map quartus_merge quartus_fit So the quartus_map still reads in all the VHDL files for that hierarchy, and at the quartus_merge stage it is replaced with the .qxp file. So for now, yes, you still need this. I believe the next release will have changes to directly allow what you want. (You could make a wrapper file for the Nios that is empty, and then you don't need all the sub-files, which is a nice temporary workaround.) I am a little concerned about using Nios this way, just because if you re-generate the SOPC system, and the Nios creation is dependent on something else in the SOPC system, and hence a slightly different Nios gets created, you are basically ignoring those changes. I don't know the flow well enough to know if this will happen, but it's a concern. Especially since Nios by itself usually isn't that large, and therefore isn't that much of the compile time, it's introducing risk to save a few minutes. (I don't know the specifics of yous situation though, naturally)
