12 years agoIncorrect printline by using different memory segments
Hi! I have a system with NIOS and several memory blocks, 2 x On-Chip, SDRAM and SRAM. All of them work well, as long as I use same memory for all segments (.heap, .data, .stack....). As soon a...
12 years agoDoes your FPGA meet all timing specs?
Have you tried running the Memory tests on the different segments? There should be nothing wrong with what your are doing. But i've see memory failures do odd things. Pete
