17 years agoimporting a partition
I am sub-compiling and logic locking a module. The source files are all called using relative paths. When I run the top level compile I get an error in the assembler stage indicating that it c...
17 years ago --- Quote Start --- I had the same problem with 9.0 --- Quote End --- Did you re-generate the QXP with 9.0 or simply try to use it with 9.0? If you generate a QXP with 9.0, you shouldn't need the original encrypted IP files to use it.
