17 years agoimporting a partition
I am sub-compiling and logic locking a module. The source files are all called using relative paths. When I run the top level compile I get an error in the assembler stage indicating that it c...
17 years agoI am only trying to generate a SOF file for the top level.
In the assembler step, I see an error indicating that it cannot find a couple files. The files use relatives paths from the subcompile directory. Since I am building the top level in a separate directory these relative paths generate errors. It looks as if when importing the partition, some of the paths are used in the top_level compile instead of just using the .qxp thanks
