17 years agoImplimenting a NCO Core.
Hi i am learning to use Quartus II, At the moment i am trying to just generate a sin wave for a stratix II board. I have set up the NCO block and got the symbol on the block diagram but i ...
14 years ago --- Quote Start --- What are the results of your simulation? Nothing at all? It isn't necessary to map the device pins just to make the simulation work. Have you configured the clock input pin in your simulation to provide a clock to the pll? You need to create a waveform file and put the clock input in it, and attribute a clock to this pin so that it can drive your pll. I hope this helps Regards, Thiago --- Quote End --- It's posible send to ADC output to visualize in a osciloscope?
