17 years agoImplementing Phase Accumulator in VHDL
Hi, I am currently in the process of designing a Phase Accumulator in VHDL for Altera Cyclone 3 Family. I realise there is an NCO Mega Function in the Altera Library. Can some one explain...
17 years agoJust to complete the story:
there is also output resolution. This becomes relevant if lut data is wider than actual output. This could be the case in virtual LUT comptations. for sine data:virtual computation is based on adding to nearest lower sine lut point a value using some of the left-over accumulator LSBs(their MSB side), and a scale factor derived from lut cosine point. The reverse is true for cosine point computations. Finally there is cordic design, I don't know how it works but doesn't use lut.
